Brand new Inspire Pro Black, tilted horizon, what else
1840 18 2016-2-9
geoff
Flight distance : 981952 ft
So got my new Inspire Pro Black, and what else in good tradtiion, it has a tilted horiton as well. Yes, its all updated, calibrated over and over, etc.
My previous Pro (White) had the same issue. Not to mention all the X3s taht have it as well.
Its just ridiculous they still roll out a faulty product. Its only 5,000 bucks...
Come on DJI, get your act together for once.
2016-2-9
geoff
Well, I returned the white for a refund, and the same will happen with the black one. SO in the end they will have more money from me, thankfully. Other than the money that I have spent previously which is quite a lot.
Yes, the worst of Microsoft...
2016-2-9
jonathanp
Flight distance : 519275 ft
Did you try adjusting horizon?  DJI has a nice shortcut:
Press and hold C2 (back right of your RC) and turn right thumbwheel at the same time.  You can do this shortcut in the air.
or
GoApp/Menu upper Right/Camera/Camera Gimbal adjustment
This works for me.
2016-2-10
imagines.and.wo
Croatia
DJI - The Microsoft of the UAV industry.
developer here, made my day.. lol again
2016-2-12
imagines.and.wo
Croatia
PaulKerry Posted at 2016-2-12 13:53
I've been writing software since the very early 80s. I spent a number of decades working on commerc ...
after ~7 years woking full time i wished lot of times to move to something another. but currently positives overcomes negatives.  but i wonder to switch industry for living.. few years, try something new..
it would be interesting. what is your currently daily job?
2016-2-12
Donnie
Flight distance : 3636782 ft
jonathanp Posted at 2016-2-10 15:15
Press and hold C2 (back right of your RC)  ...
      Jonathanp,   does the C2 have to be programmed for that task?  Does it override the command I currently have on the C2 because of the combination with the Right Thumb-wheel?
     I mean if you surprised Paul with a new  feature ( Paul has an outstanding knowledge base) I want to understand  more.
Thanks-donnie
2016-2-12
R&L Aerial
Flight distance : 298100 ft
I wonder how many other short cuts there are that not many know about? Im going to take my props off and start playing with some buttons.
2016-2-12
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
PaulKerry Posted at 2016-2-12 08:43
Excellent tip. I learned something new. Thanks for that one.
I'm going to try that for myself to  ...
It works, i did it...
2016-2-13
jonathanp
Donnie Posted at 2016-2-12 09:26
Jonathanp,   does the C2 have to be programmed for that task?  Does it override the command  ...
Hey Donnie,
No, the feature is already programed.  It's actually documented in the latest manual PDF.  I came across the feature because I was looking to control both gimbal axis from a single controller at the same time using both wheels.
2016-2-17
americanrawlins
I had this same issue yesterday, but then realized there are so many ways to fix this. The inspire is a very tricky copter to fly and has a ton of functions. This can be fixed in the camera tilt section.
2016-2-17
Farnk666
Flight distance : 1711394 ft
All Inspires have tilted Horizons - it's a DJI thing.
Adjust in the air and shoot. No biggy.
Comes back to understanding that you get what you pay for.
This is a cheap UAV in relation to professional craft - we need to keep a sense of proportion and have realistic expectations.
Doesn't mean that DJI shouldn't be working hard to fix issues however!
2016-2-17
DJI-Ken
Flight distance : 1515312 ft
Farnk666 Posted at 2016-2-18 10:09
I have flown close to 20 different Inspires and none of them had a tilted horizon.
My old P3 Pro did once in a while, but after firmware update it never did it again.
2016-2-17
Farnk666
The customer experience differs from yours then Ken. Just search the forum here and RC Groups and Inspire Pilots and the many FB groups. No shortage of reports of tilted horizon.
Perhaps the Inspires used for testing and development within DJI are more carefully calibrated and engineered than those sourced through the retail channel.
Prototypes and testing rigs do tend to be more carefully prepared than production units in many industries.
2016-2-17
geoff
Ken, since you work for Dji its obvious you say that. But to be frank I dont believe it one bit. I have owned 7, yes thats SEVEN, Inspires incl 3 Pros, and each and every one had a tilted horizon. I have seen and flown at least another 15 Inspires, in all versions and thru all firmwares, and yes every single one had the same problem. The only one that does not have a tilted horizon is my first P3P from the very first batch. My other P3P, with the new motors, has it as well.
So yes, it is a very widespread problem, which Dji tries to hide until today.
2016-2-18
DJI-Dave
Sorry this happened to your Inspire but it is not all Inspires as some here are trying to say!
Dave
2016-2-18
jonathanp
PaulKerry Posted at 2016-2-17 11:06
Jonathan, would you be so kind as to try it without your tablet/phone connected to the aircraft an ...
Hey Paul,
I just tested my X5 with the horizon tilt shortcut without the iPad connected and it doesn't work.  However the controller does make a beep sound.  When the iPad is connected a green grid also shows up on the screen when making the tilt adjustment.  I can physical see and hear the camera tilt when I make the adjustments.  So again to answer your question it appears you need a tablet connected to use the tilt shortcut.
I hope this helps.
Jonathan
2016-2-18
jonathanp
PaulKerry Posted at 2016-2-18 18:58
It does. Thank you for putting that to the test. It appears that I may have been wrong about it be ...
Hey Paul,
Thanks, yet another new trick!
Jonathan
2016-2-18
geoff
DJI-Dave Posted at 2016-2-18 23:05
So pls tell us how to fix this, rather than doubting our findings.
2016-2-18
DJI-Dave
geoff Posted at 2016-2-18 21:18
The engineering team in China is working on it.
Dave
2016-2-19
