Geebax
When you plug the battery into the charger, if it is pretty flat, then the first green LED will flash at you. As it charges the battery, the 2nd, 3rd, and 4th LEDs will progressively light up. As each one lights up, it also flashes. There is also a dull red glow from the red button LED, but not bright. This is normal.
When the battery has finished charging, all the lights go out to say it is finished charging. If you then press the button briefly, all 4 green LEDs should light up steadily, then go out after a few seconds. This indicates the battery is fully charged. If a lesser number of LEDs come one, this is a rough indication of the charge on the battery, each LED represent approximately 25% charge.
To switch the battery on, briefly press the power button and release it, then press and hold it while the 4 green LEDs march on from left to right. Release the button and it is now switched on.
The red LED under the power button should not normally be fully illuminated, otherwise it indicates a battery fault. So, if it is not coming on, then it probably means all is OK.
If any of these stages is not happening, let us know.
