Lightbridge interference?
2405 3 2016-2-18
alexlapo
Hi all, I need help, I live in the UK in a street with many houses around creating lots of interference for my phantom 3 standard I struggle to keep love you live feed after about 50 meters away, I'm thinking of getting the P3A where I know it has lightbridge instead of the wifi, will the interference still affect the P3A or is lightbridge much more Better to keep the live feed? I also heard you can change the channels from 8 to 32 is this possible?
2016-2-18
labroides
Flight distance : 9991457 ft
Lightbridge is better but still subject to interference in urban areas.
It's impossible to give numbers because the locval environments are so variable.
2016-2-18
DJI-Ken
Flight distance : 1515312 ft
Lightbridge is amazing and the distance and signal strength is wonderful.
BUT, even in your neighborhood you should way more distance than you are getting.
Watch the video below and see if that helps, if you still get only 50m range then you may need to send your aircraft in for repair.
Let me know if you still get the reduced range.
2016-2-18
alexlapo
It's only the live feed of the camera to my iPhone I can't get signal of after 30/40 meters ish the signal to fly the drone is fine I just hope the lightbridge will help with the live feed i struggle to understand how it works with the live feed
2016-2-19
