endotherm
Flight distance : 503241 ft
I agree. I bought a cheaper wifi-only iPad mini WITHOUT cellular/GPS. It works fine for everything except follow me. However, you can buy external GPS receivers and tether them via bluetooth. For IOS at least they need to be WAAS enabled and not just a cheapie GPS unit. They are typically used inside real aircraft by pilots as even the built-in units on iPads etc don't work inside a plane. I use a Garmin GLO unit myself, it is smaller than a cigarette pack. Once paired, I tested it by putting the remote controller on the ground and walked off while holding the GPS unit. The aircraft followed me without any problems, out of shot of the controller. I didn't go any great distance, and I'm not sure what the range would be, as it is a bluetooth (short range) signal and still has to tether the GPS and RC. I think it is currently 10m/30ft but bluetooth 4.0 is expected to be 4 times that.
Another advantage is that the external units also have GPS/GLONASS satellite coverage, and update the location more frequently than the internal GPS.
