nd filters that you don't have to unscrew original one?
1012 13 2016-3-4
lukx
Poland
Are there any quality ND fgilters that work with Pahntom 3 without unscrewing the oryginal one form camera?
2016-3-4
pi-inthesky
Flight distance : 13058 ft
Adding filters to your camera without removing the original will just add weight to your gimble theres no point.Is it you have a problem removing the original.
2016-3-4
torinodave
There is a kit of thin plastic films you can place on the inside of the lens. This keeps the original lens but you will need to unscrew it and replace or remove the film as necessary.
2016-3-4
torinodave
Here maybe this will help
2016-3-4
torinodave
ditzco.com is the site with the film filters that slip over the original lens.
2016-3-4
uskaper
Flight distance : 155581 ft
Slovenia
Received this one today... Will post my thoughts when I try it in practice. For now it looks and seems okay. Very lightweight and well made.
http://www.aliexpress.com/item/D ... -3/32452140596.html
2016-3-4
DJI-Amy
It might interfered the weight balance  and stabilization of the gimbal if you mount an extra filter.
2016-3-4
lukx
Poland
oh ok so do you guys recommend original dji filters because the polar pro seems more bulky?
2016-3-5
pi-inthesky
lukx Posted at 2016-3-5 10:34
I use polar pro no problems
2016-3-5
aopisa
Flight distance : 430686 ft
Maybe the search function or Google doesn't work very well as this question seems to get asked about every 5 minutes.
Taco filters are very light, < 2grams.
http://taco-rc.com/taco-rc-nd-fi ... ance-free-shipping/
2016-3-5
Ulysse
Flight distance : 1389931 ft
Belgium
The more you put pieces of plastic or glass in front of a lens the more you degrade the quality : this is true for every lens, even premium ones.
The Phantom picture quality being what it is (bad), it is better to avoid adding a filter over another one.
2016-3-5
kjmarsola
torinodave Posted at 2016-3-4 17:55
I tried them and they were horrible, flimsy, and impossible to install or remove, with out getting fingerprints.
A little thicker than saran wrap, but not much, if you are installing them do so in a wind free area, or they will blow away.
They couldn't cost more than  .99 cents to manufacture. but cost $28.95 or $34.95.
2016-3-5
DJI-Ken
Flight distance : 1515312 ft
I have DJI filters as well as Polar Pro filters and they all work great.
Unscrewing is a bit difficult, but if you hold the lens with 3 fingers equally spaced around the lens cover and twist without squeezing too tight it comes off just fine.Be careful whe removing the lens as to not lose the rubber o-ring.
2016-3-5
aopisa
kjmarsola@gmail Posted at 2016-3-6 01:54
I tried them and they were horrible, flimsy, and impossible to install or remove, with out getting ...
I agree. They were a pain to use and very hard to avoid fingerprints.
2016-3-5
