I want to know the note when updating firmware v1.4.0.10 inspire1...
1000 9 2016-3-15
thuytc80
Vietnam
I want to know the note when updating firmware for inspire1 from v1.4.0.10  -to- firmware v1.6.0.40
I'm not sure for this
Thanks you very much!
2016-3-15
Tharg (from the
Flight distance : 120784 ft
b sharp or possible c sharp
2016-3-15
thuytc80
Vietnam
Tharg (from the Posted at 2016-3-15 17:52
I do not understand. Tharg?
2016-3-15
Harb
thuytc80@gmail. Posted at 2016-3-15 21:55
You can find the Notes on the DJI downloads page
2016-3-15
Machoman
Flight distance : 1036959 ft
Austria
1.4.10 is the much better firmware
- circumvent the 500m alt limit
- stable flight
- no geofence forced update trigger
The only downsides are no osmo support for the camera and no gimbal smooth adjustment and the bug that camera makes a small movement when you push stick left and right. If you need one of this you must upgrade otherwise think twice and read more postings about the many issues with fw 1.5+
2016-3-15
thuytc80
Vietnam
Thanks all. But i not sure with firmware 1.6.0.40 for inspire1.
2016-3-15
Tharg (from the
Machoman Posted at 2016-3-15 14:18
The movement when you move the stick left or right is not a bug - It's a feature that is based around predictive movement centered on the 'dead zone' +/- 5 degrees from centre working in conjunction with the PID tuning.
If you think i is a bug you do not understand how it works.
2016-3-16
Machoman
Austria
Tharg (from the Posted at 2016-3-16 16:19
The movement when you move the stick left or right is not a bug - It's a feature that is based arou ...
The bug is that this movement cannot be turned off in 1.4.
Before it was only turned on in FPV mode.
After 1.4 you could not get rid of it anymore and it was turned on in any mode. It was annoying and there were many complaints about this also in this forum.
After 1.5 you can disable it again.
2016-3-17
americanrawlins
Tharg (from the Posted at 2016-3-15 18:52
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHA~!!!!!
2016-3-17
DJI-Ken
Flight distance : 1515312 ft
Here are the release notes.
http://dl.djicdn.com/downloads/i ... _Note_en_160317.pdf
2016-3-17
