Cant connect lightbridge to lightbridge assistant
1270 3 2016-3-18
skyrisaerialpho
Flight distance : 43494 ft
Hi, Can anyone help, I have moved from 3dr gear to dji but having trouble with lightbridge.
I can connect my s900 to the pc via usb and a2 assistant to map channels no problems.
I want to connect the lightbridge to the pc to check for updates map channels etc/. but for the life of me I cant connect via usb.
Lightbridge assistant v1.3 shows no sign of connection and cant update or check firmware. there is no response with channels either.
In the A2 assitant I can see movement in the channels when connected via dbus so I know lightbridge is working
Any ideas why I cant connect
thanks in advance
2016-3-18
DJI-Adela
Hi,
Please make sure the USB port and the USB cable are in good condition.
Here is the basic steps for using the Assistant software, for more details, please refer to the user manual at http://dl.djicdn.com/downloads/lightbridge/en/Lightbridge_User_Manual_v1.04_en.pdf
2016-3-18
skyrisaerialpho
Hi Adela, I have tried this, it doesnt connect. the indicators dont change this is the same with the air unit. I cant map channels so I cant fly, I really dont know what to do.
2016-3-19
skyrisaerialpho
is this a driver issue, I can use the usb to connect  the a2 assistant!
2016-3-20
