Camera option not showing up on App!
724 6 2016-3-19
rogerskeenan
So I just bought a Phantom 4 today. After I turned everything on a plugged it in I began to connect my Ipad to the Phantom. I went on the GO app after turning everything on and where it should say "Camera", it just says how to connect. I've tried new cables and I've tried other devices. Nothing works. HALP PLZ.
The light on the RC is Green and I can move the camera Gimbal a little bit but outside of that, I've got nothing.
2016-3-19
rogerskeenan
Update: I got it to work on a Samsung phone, but nothing on any apple devices I've tried, any thoughts as to why?
2016-3-19
mail
Flight distance : 491962 ft
Are you certain that your lightning cable is plugged in tot the USB port on the RC and not the mini USB port with the adapter cable?
2016-3-19
quickpoint
mail@andyschwar Posted at 2016-3-19 20:54
Are you certain that your lightning cable is plugged in tot the USB port on the RC and not the mini  ...
makes sense but common sense,  plugin lightning straight into the usb port rather than the adapter used to upgrade the p4 by the micro usb to female usb adapter to plug in your lightning cable into
2016-3-19
rogerskeenan
mail@andyschwar Posted at 2016-3-20 08:54
I plugged an apple Iphone charging cord into the micro usb adapter and then into the micro USB port. Is that wrong?
2016-3-20
rogerskeenan
Nevermind I fixed it. The problem was I'm dumb.
Thanks for your help!
2016-3-20
mail
Haha. Well if it makes you feel any better, the only reason I mentioned my solution, is that I did the same thing.
2016-3-20
