endotherm
Flight distance : 503241 ft
Your understanding is basically correct, lightbridge is the technology, and the way it is implemented may be slightly different between models, e.g. integrated or separate, 2.4 or 5GHz. This might explain it a bit better. There is also a master/slave configuration described which may be what you are after.
The quality of the transmission will vary depending on surrounding interference, weather conditions, obstructions, reflections etc. It will hop frequencies and alter the bitrate to cope with degraded signals. BTW, I think the current version only outputs 720P. I take it you want to receive the transmission and re-transmit it to a remote site. There is an add-on module you can buy which provides HDMI out from the receiver/controller. You could feed this to another video transmitter/receiver combo to re-broadcast to a remote location.
It's never a good idea to let the aircraft out of line of sight, or behind obstacles. The forum is littered with posts of crashes from those that do. Your transmissions will mostly be reflections and it will be pot luck as to the quality.
Hope that helps a bit, I'm no expert. |
