Punchbuggy
Flight distance : 483166 ft
Use Assistant 2.
The battery firmware is embedded in the craft's firmware. When the craft firmware upgrade process is initiated via Assistant 2 and it needs to update the battery firmware too, the two middle LEDs on the battery start to flash to indicate it is happening. If you have more than one battery, when returned back to the firmware screen in Assistant 2, power down your craft, swap batteries, and power back up the craft - then just perform a refresh at the same firmware level to apply the battery firmware to the other.
I'll have to confirm, but I think the battery firmware level is listed on the battery screen in DJI GO. |
