DJI Assistant on Win 10
752 4 2016-3-25
markhowerton1
I installed the DJI assistant on my laptop and the screen is about 2" X 3" and the fields are jumbled together.  Changing the resolution didn't work. Any ideas?
Mark
2016-3-25
stshields91
Flight distance : 1483635 ft
what resolution are you running?  I have it installed and working fine on 1920X1080 and a much higher resolution Surface Book and both are fine.
2016-3-25
markhowerton1
stshields91 Posted at 2016-3-25 15:58
what resolution are you running?  I have it installed and working fine on 1920X1080 and a much highe ...
I tried several resolutions and none worked.  The app gets a little bigger with a lower resolution but it's not usable.  Don't have my laptop with me but I started around 3900 X 1900.  It works on another win 10 laptop but I would like it to work on my new one.
Mark
2016-3-25
cp_muzz
Try switching to 1080p resolition then restart you PC. I had a similar issue and that seemed to resolve it. You can also try logging out and logging back in to your user account. I hope it works for you
2016-3-27
Ulysse
Flight distance : 1389931 ft
Belgium
May be do you have a non standard (100%) text size ?
2016-3-27
