Geebax
'It's really disappointing to see only users tracking this post instead of somebody from DJI finally stepping in to note that this is being looked at. It is clear that the camera is NOT taking 4K video and is instead taking 1080 video and upscaling it to 4K with an algorithm. '
I was drawn back to this discussion. You will not get people from DJI commenting on this because it is not an area in which they have the expertise. Someone like Ken may obtain advice from DJI in China and post the replies, but that is as far as it goes. Once upon a time DJI experts in various fields used to come on this forum, but it just does not happen any more, probably got fed up with the abuse.
While I don't have a P4, I do have a P3P and it most certainly does shoot in 4K. and I am quite familiar with the image processing chip used in the design and it does say in it's specifications that it is capable of recording 4K video material. Therefore, I would ask the question, why would DJI downgrade the video recording characteristics on the newer product? The answer is that they would not do so.
And from a purely technical standpoint, you cannot upscale 1080 x 1920 material to 4096 x 2160 and make it look good because you cannot manufacture resolution, no matter what algorithm you use. You can however downscale from 4K to 1080 quite well, especially if you use high quality programs to do so. And people will say that 1080p looks great because the vast majority of people cannot view 4K material on anything, while most monitors these days support 1080p natively.
Having said that, I am still trying to figure out why your material does not look good, so far there have been no clues, however I have viewed original footage from a P4 and it was stunning, just noticeably better than that from my P3P, so your experience is not typical.
So, I have two questions, what is the resolution of the monitor you are viewing your material on, and what make and model is it. And secondly, can you post an original piece of the video you are talking about via Dropbox or similar.
The last thing is that you mention earlier that the examples you showed were a 'screenshot'. Most people relate to a screenshot as a section capturted from their display screen, in which case it then also is subject to the processes inside the monitor and is not representative of the image. If you took the shot another way, perhaps explain how you did it.
