Donnie
Flight distance : 3636782 ft
RC fiddy 1, You mean you must add power ( Left Stick Forward ) when forward Pitch (Right Stick Forward ) is applied, is that correct? If so These are a few things I would do , first do a IMU calibration and Compass calibration.
When you do the IMU calibration make sure surface is perfectly level, check with a level and adjust as necessary. After calibration starts stay away for at least 10 minutes because even the floor vibration can affect proper calibration of the aircraft, do it indoors and stay away from as much metal as you can. When doing compass calibration do it in a wide open field away from ANY METAL, make sure transmitter is at least 15 feet away as well, no wrist watch or change in pocket as well, keep in mind that concrete sometimes has metal" re- bar " in it, so a open field is your best bet. Once you set these there is no need to keep repeating. Only if you travel more than 100 miles from the calibration site or after a hard landing or firmware update is it really necessary. Do it once and do it properly.
After you do these I would also do a RC calibration ,this is fairly simple and is on the Go app . In RC settings. Also check all of the Gains and Expo settings and make sure they have not changed. You could even turn up the gains about 10% to start. I think the problem lies in the calibrations , I would start there and then adjust the gains if you dont get success. Remember the Higher the number in Gains and Expo the more responsive the aircraft is going to be and the lower the numbers or % the More Mushy Or unresponsive the craft will be . Make sure the Gains have not dropped, the default is 100%for Pitch, Roll, Yaw, and vertical. Gain is how the aircraft reacts to forces when there is no Imput from the RC transmitter, How it reacts to wind and Up drafts and down drafts as well. All of the settings must be monitored in" standby mode" or they will indicate 0 on some of the settings . ( Flight ready , like right before takeoff, all system on )
Make sure the updates are current, the latest update did not effect the ( 1.7 was a camera update on the inspire 1 ) aircaft, but did effect the RC You have the update complete on the RC Transmitter as well correct ?
good Luck- brother donnie ................Keep me posted
