Phantom 2 Windows Drivers Fail to Install
3524 7 2016-4-3
brdemorin
Everytime I try to install the Phantom 2 Windows drivers for my Win 8.1 machine, it tells me the install failed. I can't get these drivers installed successfully!
I've now repeated 5 different times where I uninstall drivers, reboot, and try again. I follow the procedure properly by installing the drives first, wait for the prompt to connect the MC, then it acts as though it's installing only to finished by saying the install failed.
Please help!
2016-4-3
BWJ
Denmark
Try to start PC in failsafe and install driver, works for me.
2016-4-3
brdemorin
Already tried a safe mode install. No go
2016-4-4
DJI-Paladin
Flight distance : 2408 ft
Hello, is the win 8.1 32bit or 64bit? I've tried it on win7 64bit everything runs normally. You can also try to run the install program as administrator
2016-4-5
Toelis
Try this workaround. It works by me, using Windows 10 64-bit.
http://flitetest.com/articles/dji-naza-m-windows-10
2016-4-8
jamescraven76
I did the same thing as Toelis suggests and it then worked for me. The only thing is once you do the shift/restart it took my computer a good while to get to the next step but after that it was fine!
2016-4-9
reb10
Having same problem with Windows 8! How did you resolve this?
2016-4-27
reb10
brdemorin@yahoo Posted at 2016-4-4 19:13
I'm having the same issue! Have you resolved it? If so could you let me know what you did?
2016-4-27
