HUAWEI P8 lite
flydodom
Flight distance : 321857 ft
Hi guys
I got an ipad air 2 (9.7" screen size) it works well but it is quite heavy on the RC. I am looking for 5.5" screen alternative in a budget price.
Thanks!
2016-4-5
DJI-Paladin
Flight distance : 2408 ft
Hello, P8 lite is no in the compatible devices list. i'd suggest you to use the devices in the support list as below: 兼容列表.JPG
2016-4-5
flydodom
DJI-Paladin Posted at 2016-4-5 11:47
Hello, P8 lite is no in the compatible devices list. i'd suggest you to use the devices in the suppo ...
Thank you!
2016-4-5
studio.jurdan
Belgium
so if we listen to you, only 10 phone in the world are compatible?  in this case  push the phone in the box with the DJI product. i just buy a P8 lite and waiting for the OSMO but if it not works be sure you'll ear me for years !   did you porject to buy any car witout motor?  and when you ear that you can push any motor in, then you read here that only 4 GOLDED motor are good!!! what did you think about that???
2016-6-24
Geebax
studio.jurdan@g Posted at 2016-6-25 12:48
so if we listen to you, only 10 phone in the world are compatible?  in this case  push the phone in  ...
Stupid suggestion, phones are not the same in different parts of the world. And you have been given a list of what phones/tablets work, if you can't accept that advice then you are a fool.
2016-6-24
studio.jurdan
Belgium
did you buy a car without motor butr compatible wiht all motor in the wortld AND AFTER
you see that the only motor compatibles are at the same price that your car ?????
the compatible list is 600€ phone or OBSOLETE 2013 un findable now oneso it is time to make a REAL NEW LIST PLEAS
2016-6-25
johnwarr
Flight distance : 6467 ft
DJI publish a list of recommended devices for each of their products that have been tested as 100% compatible.
Maybe a few seconds research before buying would have been useful ?
Many "other" devices will work to some degree, but its a case trial and error if you go down that route.
New devices are released nearly every month, its unrealistic to expect DJI to test every new one that comes to the market.
You can still fly perfectly well without any mobile / tablet connected.
2016-6-25
Show Me Drone
studio.jurdan@g Posted at 2016-6-25 10:48
Lost in translation
2016-6-25
fans536596bc
Flight distance : 3396 ft
Greece
As a newcomer to the wonderful DJI drones, I have to agree with -what I believe- studio.jurdan wants to say. It is very confusing to select an android device that is guaranteed to work with the drone's app. Many of the listed devices are not available in retail stores any more. For example, try to locate and buy a Huawei P8 Max if you can.  I can find several Huawei models in stores but P8 Max is out of stock. So should I buy a similar device and experiment, risking wasting my money? A lower-priced unlisted device with higher-specs than those listed? I understand why DJI wants to be sure a device is fully compatible, and proper testing takes time. But in the fast-changing Android device-world, that probably defies its purpose.
2017-1-16
Phantomjim
Flight distance : 97539 ft
DJI-Paladin Posted at 2016-4-5 02:47
Hello, P8 lite is no in the compatible devices list. i'd suggest you to use the devices in the support list as below:[view_image]
I'm using  two devices that are not listed by DJI and both are running 100% Ok.
Samsung Tab (A) 9.70" and the LG G4 5.5"
2017-1-17
Messi's dad
Flight distance : 3946417 ft
China
Chinese????
2017-1-17
Lamas
Flight distance : 29590 ft
I use the huawei p8 lite and it works fine with the phantom 3 standard, i tried a couple of times, it's not on the list from dji, i wonder why? other people online claimed it to work, so i tried it and it really works well!
i had some signal lost but that started to be about 400 meters of distance. i guess to p8 lite 2017 version will work also, but i haven't tried yet
2017-10-7
Geebax
The answer to this is quite simple, to do the complex job that the Go Apps do, it requires a powerful phone or tablet. This is why DJI publish a list. There is no point in getting upset because your crappy Android device does not work, get one from the list of recommended devices and you should be OK. Or get an Apple device, most of them seem to work OK.
2017-10-7
Lamas
well i fly with my p8 lite so many times, works great to me, so what's your sugestion to why it's not compatible, honestly it works fine!!
2017-11-22
Lamas
not true, works well, fly more than 40 hours with it, the 2015 version!
2017-11-22
Perezq
Colombia
Hi! I Just got de Mavic Air and I own a Huwei P8 lite. I succesfully fly my drone with the DJI Go 4 app with my phone BUT I can't manage to link de Remote to my phone. The "charging" icon blinks, it goes on and off when I connect my phone to the remote.  This is what DJI means, that my phone is incompatible? or the cable might be foulty?
2018-4-29
Earroyo
Perezq Posted at 2018-4-29 18:31
Hola, yo tengo un p8 lite 2017. el problema de tu telefono puede ser el conector .
2018-8-21
Earroyo
Hola, estoy mirando las especificaciones de mi teléfono huawei p8 lite 2017 y según parece funcionará para volar un Mavic pro. La APP la he instalado y va perfectamente, aunque aún no la he probado con el Drone. Puede alguien sabe si funcionará?
2018-8-21
