Hardening your P4 foam case (for cheap)
3116 19 2016-4-5
P2-I1-P4
Flight distance : 3657356 ft
I put several layers of Elmers glue on the outside of the foam case that the p4 came in. The glue dried almost clear with milky whitish spots in the heavy spots and it took me a couple of day to coat the entire case with several coats. I just squeezed it on and smeared it around with two fingers, that's it. Now it's hard and alot more durable when being put into the trunk of my car and on the ground etc when I'm out. A small bottle cost $1.25 (US). Alot of other glues will melt the foam but Emers white glue is just fine and at the right price. Didn't figure I need a $100+ case when there a perfectly good already here.
----- update -----
After four coats applied to the entire case and dried completely (after 2 days), it looks as if there is nothing on the case. So a picture would show a case that looks excactly like how it showed up in the mail (new).
2016-4-5
DJI-Paladin
Flight distance : 2408 ft
It sounds cool. It would be better to post a picture here
2016-4-5
RedHotPoker
Flight distance : 165105 ft
How many bottles of Elmers Glue did it take to cover the case?
Please post a sticky pic. ;-)
RedHotPoker
2016-4-5
P2-I1-P4
RedHotPoker Posted at 2016-4-6 14:47
One small (4 fl oz.) bottle. of Elmer's "School Glue". safe and non-toxic.
after it dried completely it looks as if nothing has been put on it. And the shell is harder and will dent slightly in extreme gouging test, but it didn't break off or crack like styrofoam like to do.
2016-4-6
Rob_stal
Flight distance : 1243038 ft
P2-I1-P4 Posted at 2016-4-7 14:47
after it dried complete ...
Elmers is water based, if you are in a humid climate or near the ocean, would it not become tacky?
I have experience this in the early days of 3D printing when I used elmers on the print bed to assist with print adhesion, the glue would be tacky on humid days.
Cheers
Rob
2016-4-7
Li.F
Or get this bag for around $90 bucks and put a lot more stuff in, and be rain proof :-) Just got mine yesterday and already deeply in love with it over original foam case... (I got second battery and the second one wouldn't fit anywhere in the foam case..) Best bang for the buck, and exactly the same as the official DJI Phantom 4 backpack that they sell for $330...
Phantom 4 Backpack
2016-4-7
TK-421
Banned
2016-4-7
Rob_stal
Li.F Posted at 2016-4-8 12:52
Or get this bag for around $90 bucks and put a lot more stuff in, and be rain proof :-) Just got min ...
The foam case has cut outs for 2 batteries.
2016-4-7
R&L Aerial
Flight distance : 298100 ft
Rob_stal Posted at 2016-4-8 02:42
I can't fit two extra batteries in my p4 case???
2016-4-8
Li.F
Where exactly do you fit extra batteries in the original P4 foam case? A photo illustrating that would be great! Coz I can't figure out
2016-4-8
Jkeller84
Flight distance : 396955 ft
Li.F Posted at 2016-4-8 09:25
Where exactly do you fit extra batteries in the original P4 foam case? A photo illustrating that wou ...
2016-4-8
Jkeller84
Cool idea. Wondering if the glue will get sticky when it gets wet or around moisture. Check out what I did to my case
2016-4-8
Jkeller84
R&L Aerial  Posted at 2016-4-8 08:42
See picture I attached above
2016-4-8
connorschulte
Flight distance : 261033 ft
Li.F Posted at 2016-4-7 21:52
I have seen this bag online and because the bird faces down, wouldn't the props get damaged from pressing against the bag? Or at least rip the material.
2016-4-8
Li.F
Wow... I tried to fit my extra battery into one of those slots and never thought about putting them in horizontally... Bummer, Thanks a lot!
2016-4-8
R&L Aerial
Jkeller84 Posted at 2016-4-8 09:44
Thanks for posting this.
2016-4-8
Rob_stal
Jkeller84 Posted at 2016-4-8 23:35
Cool idea. Wondering if the glue will get sticky when it gets wet or around moisture. Check out what ...
I saw that in one of your other posts, very well done it really came out nice.
How is the Plasti Dip holding up, it's been a few weeks now since you coated it ?
Cheers
Rob
2016-4-8
bmchollan
Flight distance : 481677 ft
India
This is potentially a dumb question, but . . . Do all of the Phantom 4 "packages" DJI sell (drone with 1 battery, drone with 2 batteries, etc.) come with the foam case?  In the DJI store the only one that shows a picture of the foam case is the drone with 1 battery.  I want to buy the drone with 2 batteries, but definitely want the foam case too.
Thanks . . .
Bruce
2016-6-6
djiuser_Nkhc8VD
Malaysia
bmchollan@gmail Posted at 2016-6-6 14:49
Thanks . . .
Bruce,
I think either you buy a Phantom 4 with one or two or even more batteries, they will give you the same foam case which have 2 compartments for extra battery. Means you could only able the fit in maximum 3 batteries. One attached with the drone, two on the battery slots.
Adrian
2018-1-3
Kuya Kano
Flight distance : 797913 ft
Philippines
May I ask what is the purpose of "reinforcing" the case that is intentionally made to take the brunt of force when dropped or damaged?
I travel with mine in the  Smatree Backpack for Phantom 4 Pro  .  And when I'm traveling overseas, I add a couple layers of clothes around the outside of the hardshell within the backpack for extra padding.
Samtree Backpack for Phantom 4 Pro
2018-1-3
