Poor radio signal
1321 4 2016-4-16
djelmore818
I have an Inspire 1 V2 and when I am flying the radio signal is poor and sometimes jumps to good but only for a second. I am in the wide open country side with no power lines, buildings or any other type of structure. I fly out 300 yards and start to get latency in the video and sometimes just loose the whole app as a whole. I have the latest update and now I am just searching for answers. I know the Inspire has a much longer range than that?? Any help would be appreciated.
2016-4-16
Farnk666
Flight distance : 1711394 ft
Follow this thread
http://forum.dji.com/thread-27147-1-1.html
2016-4-16
terrylewis
Flight distance : 3517287 ft
Along similar direction provided by Farnk666, review DJI-TIM's tutorial available in this thread......
2016-4-17
Aeromirage
Flight distance : 1778045 ft
Be sure that your antennae are NOT pointed in the direction of the aircraft. The signal radiates from the sides of them, not the tip.
2016-4-17
DJI-Ken
Flight distance : 1515312 ft
If you are getting poor signal and video latency at 300 yards in and open area and away from interference I think the problem may be your device. What device are you using? Below is the recommended devices, if you are not using one of those then your device may not have the processing power to make the app work. You can also try to lower the video transmission bitrate in the image transmission settings. Choose custom and then select the best channel and lower the bitrate. If you are in CE mode this option is not available but search the internet for a workaround.
Also here's a video to properly direct your antennas for best reception.
iOS Version v2.7.2.
Requires iOS 8.0 or later. Compatible with iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus,iPod touch 6,iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, and iPad mini 3 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plus.
Android Version v2.7.2. Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
2016-4-17
