CloudChaserCT
Flight distance : 8031880 ft
To Update the Remote, its easier to use a USB thumb drive at least 4 gb or 2 gb will work, format it to Fat32, and start 1 FW update at a time till you get to the current one, Just go to the Downloads page and Download the FW files starting with the one after your Version. Its the best way to do it right, you may miss something when just jumping FW Files. Drag and drop the down loaded WM610_FW_V01.03.00.00.bin file to your USB Thumb Drive, turn on Remote ONLY with NOTHING else connected and wait till the FW completes, then move to the next FW WM610_FW_V01.04.00.10.bin File and drag n drop it onto your USB Drive, but don't forget to delete the last files first. And update as before then delete files off the USB Drive, empty trash. Also make sure you restart your Remote After Each Update before the next, and then shut it off.
From this point make sure your iPad is up to date with the app being Version 2.7.2, and see if you can connect your Remote to the iPad App Only. If so you should be able to upgrade your Remote directly from your iPad, BUT DONT DO IT. As with the latest FW WM610_FW_V01.08.01.00.bin you need to Update the Inspire FIRST. Also make sure you upgrade your Inspire to each of the new FW updates as you do the Remote. Its truly very simple. If you cant connect to you iPad Still just keep loading the next FW Files one at a time till you reach the Latest one, and then do the upgrade as suggested in the How to Update your Inspire. |
