RTH or Auto Land
1742 13 2016-4-23
romeogolf70
Phantom 3 Standard, flew out of contact with RC and it auto landed. Isn't it supposed to RTH? Can I change this?
2016-4-23
Aardvark
Flight distance : 384432 ft
In  DJI GO, go to 'Main Controller Settings' / 'Advanced Settings' and scroll down, you will see 'Remote Controller Signal Lost' chose which option you want 'Return to home', 'Landing' or 'Hover'. And that should help.
2016-4-23
richmars
Flight distance : 209537 ft
I think there's an option in the DJI Go to select what to do when the signal is lost. Options are RTH or land (I think)
2016-4-23
gkasznia
Flight distance : 232064 ft
richmars Posted at 2016-4-23 12:44
I think there's an option in the DJI Go to select what to do when the signal is lost. Options are RT ...
ya there is also a hover option
2016-4-23
clala
It's in the settings
2016-4-23
J.N
Flight distance : 102333 ft
Do always the check list before fly. Return home is the best option. when Landing option is chosen you risk to much cause the bird can landing no matter where, in a lake, river a roof, or in another place you cant reach it.
2016-4-23
ADDvanced
Flight distance : 76204 ft
What is the default setting?
2018-1-2
Labroides
Flight distance : 9991457 ft
ADDvanced Posted at 2018-1-2 20:08
The default Loss of Signal setting is RTH.
Unless you change it, that's what your Phantom will have set.
2018-1-2
solentlife
Flight distance : 1087530 ft
Latvia
Don't forget to make sure ALTITUDE of RTH is high enough to clear all obstacles ...
AND don't forget that you can actually guide AC round items while still RTH acting ...
AND don't forget that if AC is at higher altitude than RTH setting when RTH kicks in - it will stay at that high altitude till you make it descend or it gets vertically over Home Point.
Nigel
2018-1-3
PeteHB
On the subject of return to home if the RTH is set at say 50M but you are flying at 100M when signal is lost or RTH initiated will the drone descend or RTH at its operational hight?
If it drops to 50M and there are obstacles in the RTH path and the drone is a P4 series and has collision avoidance will it be effective in avoiding the obstacles ?
2018-1-3
Labroides
PeteHB Posted at 2018-1-3 03:04
Your Phantom will never descend to RTH.
It will come home at whatever altitude it is if higher than RTH height.
Obstacle avoidance will work if enabled and conditions are suitable (good light etc)
2018-1-3
solentlife
Latvia
Already answered in post #9 .....
Obstacle avoidance - better not to rely on it !!
Nigel
2018-1-3
PeteHB
solentlife Posted at 2018-1-3 03:29
Missed the post probably typing at the same time.
2018-1-3
solentlife
Latvia
PeteHB Posted at 2018-1-3 04:01
No worries ... and not being rude ...
Have a good one ...
Cheers
Nigel
2018-1-3
