Aeromirage
Flight distance : 1778045 ft
Yes, like dobmatt said, use a wide rubber band and your hand only. Don't put pliers to it! That will bend the ring making it oval. It will come off. And, yes, you want to remove it as it takes the place of a filter to achieve balance. If you just add the filter, it will be front heavy and stress the gimbal motor and possibly vibrate. |
