DFWdude4DJI
Flight distance : 1974501 ft
It also depends on what grade of CF props you use. There various brands out there and many of them are cheap which, to me, tells me that they don't balance them well enough. I purchased T-motor CF props for my Inspire Pro and they arrived perfectly balanced. The advantage of CF props vary though. If you're using really good CF props like the T-motor props (they taper off like a knife and are a little sharp) and a bird flies into your props, usually the bird would go (chop, chop). But if you crash or hit something hard with your CF props, you may blow a motor or two. |
