Fix for not flying straight
1891 13 2016-5-29
PartsGuy
Flight distance : 418346 ft
Is there a fix for not flying straight? I noticed this to today. I was trying to fly down the middle of a narrow (20 feet wide) street lined with flags. I took off in the middle of the street , went to about 10' high and started down the street slowly. I constantly had to nudge it back to the left. Before we get to far let me state that I had permission to do this. It's a city cementary and there was no one there. My bird is the P3P and is up to date. I did an IMU check and calibration about a week ago and a compass calibration at the same time. Both were successful. After the update I kept getting weak or no RC  signal warnings so I relinked the RC to the AC and it has been fine. I thought it might be my control so turned it around and flew back and had to nudge it back to the right constantly. Is there a fix? Could my compass calibration be off? Value on the compass before the flight was 1366. There are small power lines that go across the front and back of the cementary and the closest I was to them was about 50'. Any ideas?
2016-5-29
gil
Flight distance : 1379308 ft
It's probably just the wind.  I've noticed when I'm flying an initial Points of Interest pattern that I have to make corrections.  When it flies the actual pattern using the GPS it's ruler straight between points.
2016-5-29
markaguille
Flight distance : 2031818 ft
Guernsey
Try setting up a waypoint at either end and flying that. As gil says probably just wind.
Which way were the flags blowing? Do you have the video?
2016-5-29
DJI-Paladin
Flight distance : 2408 ft
Hello PartsGuy, could you please sync your flight record and leave me your dji account here? I'll take a look.
2016-5-30
PartsGuy
DJI-Paladin Posted at 2016-5-30 03:43
Hello PartsGuy, could you please sync your flight record and leave me your dji account here? I'll ta ...
cutlerc is account
2016-5-30
DJI-Paladin
Full email address of your DJI account is necessary.
2016-5-31
PartsGuy
DJI-Paladin Posted at 2016-5-31 19:38
Ahhh. cutlerc@kanab.net
2016-5-31
DJI-Paladin
What's the details of this issue?It would be better to tell me the flight time, distance as well as the accurate time.
2016-5-31
PartsGuy
DJI-Paladin Posted at 2016-6-1 00:10
What's the details of this issue?It would be better to tell me the flight time, distance as well a ...
Now I'm confused. What in the world are you talking about? You ask me to sync my flight records and give my email address and I do. Then you ask this?
2016-6-1
DJI-Paladin
PartsGuy Posted at 2016-6-1 18:54
Now I'm confused. What in the world are you talking about? You ask me to sync my flight records an ...
Sorry for your confusion. When I finish syncing, I get numbers of records. It would be better to point out the typical one to show the issue.
2016-6-1
PartsGuy
DJI-Paladin Posted at 2016-6-1 04:57
Sorry for your confusion. When I finish syncing, I get numbers of records. It would be better to p ...
The last flight was the most noticeable. Any of the recent flights show some drifting to the left when flying away. The last flight was what prompted me to ask about it.
2016-6-1
DJI-Paladin
PartsGuy Posted at 2016-6-2 08:51
The last flight was the most noticeable. Any of the recent flights show some drifting to the left  ...
Thanks for your information. I've checked some of your recent flights.The drone did drift left a little bit (the drifting time was about 2 or 3 seconds) but it kept holding its attitude and responded to your command correctly. You don't need to worry about this and this issue is acceptable. What's more, I'd suggest you to change a set of new props and calibrate the IMU of your drone.
2016-6-1
stefk1987
Flight distance : 518176 ft
Greece
DJI-Paladin, what if we have new props and emu calibrations?? please advise us something else. i had the same issue and your answer was the same. PartsGuy i tried with another iOS device. the problem has solved but...
yesterday the same issue returned. i do not know what to say. maybe it is caused by the wind.. dji can't answer.
2016-6-2
PartsGuy
DJI-Paladin Posted at 2016-6-1 21:08
Thanks for your information. I've checked some of your recent flights.The drone did drift left a l ...
Thank you. The issue reveals itself while flying in relatively close spaces. I will try new props first. The IMU calibration seems to be fine and now it's summer I don't want to extend startup times if I can avoid it.  Thanks again!
2016-6-2
