P4 GO APP compass arrow
3049 7 2016-6-9
mmarkoe
Flight distance : 15135 ft
My P4 flies great. Using a Samsung Tab A 8" Tablet. The red directional arrow point is always pointing backwards. I've tried searching for a way to re-orient it. Seen things like:
1. Compass lock on arrow, but do not see one.
2. Seen it said the Tablet itself must have a compass which the Tab A does not.
3. Walk Tablet in figure 8s before flying which if there is no compass in Tablet seems irrelevant.
As the compass in GO APP seems to always point towards back I guess I can live with this but if it is re-orienting as P4 flies I wonder if there is a way to get arrow point facing forward?
Thanks,
Marty
2016-6-9
DJI-Paladin
Flight distance : 2408 ft
Hello Marty, when your RC is right behind the drone, the red arrow should be upwards in the screen. And this arrow is related to the drone sensor data and mobile device sensor data especially the compass.If its direction is not right, it is necessary to calibrate the drone's IMU and compass as well as the mobile device's compass. Here is an introduction of this attitude indicator :
2016-6-9
c.davies60
My compass arrow changes to fixed or rotating map if i tap it, or have i read this wrong ?
2016-6-13
Airspace Explor
c.davies60@btin Posted at 2016-6-13 10:07
Your tablet has a magnetic field sensor. The Samsung Galaxy Tab A does not.
2016-6-13
mmarkoe
DJI-Paladin Posted at 2016-6-10 02:47
Hello Marty, when your RC is right behind the drone, the red arrow should be upwards in the screen.  ...
Thanks for the video and info as relates to the Controller orientation. The problem has existed since purchased in March. IMU has been calibrated several times and both always show proper functioning in DJI GO app. Problem is likely the Samsung Tab A 8" which works well in every other way does not have a built in compass.
Marty
2016-6-13
labroides
Flight distance : 9991457 ft
mmarkoe Posted at 2016-6-14 08:07
Thanks for the video and info as relates to the Controller orientation. The problem has existed si ...
Specs for the Tab A indicate that (unlike most Android tablets) it does not have a compass sensor.
So the app has no idea what way the tablet is pointing and is unable to orient anything properly.
2016-6-13
Airspace Explor
mmarkoe Posted at 2016-6-13 15:07
Have you tried the C1 & C2 button customization yet?
2016-6-13
fanse7fbeb63
It turns out the answer to this is incredibly simple. In order for the red arrow to be pointing in correct direction, the front facing camera direction, you must have the RC directly behind the Phantom 4 facing the battery when you start the RC and airplane.
Marty
2016-12-9
