I just updated my new battery with the 1.8.80 firmware. While the aircraft updated the two l.e.d. Lights were on with one flashing. When the gimbal light went solid green and I checked the SD card with it showing success. I then took it out and flew with no problems. My question is that on one of the prior updates when I flew the older battery's the red light stayed on the whole time I flew. This did not happen until that update was applied. I now have two battery's that the power light stays on with the LEDs and one where the power light is off. Which is correct?
Hello rprobinette, normally when you turn on the battery , the power button of the battery should be on and stay steady red.Could you post some pictures of this issue?
