Donnie
Flight distance : 3636782 ft
Just make sure that you are in the 60 foot radius when di-s charging the battery down and the RTH wont Kick in .
Also did you not hear or see the warning Pop UP ?
I do the seam thing as you , here is how I do it. I fly my aircraft down to 25 %, then I keep the aircraft close to me (within 20 meters,) I practice Landing maneuvers and spot landing etc, then when I get to about 7 %,- 10 % ( depends on weather ) I keep the aircraft in a 1 foot hover ( Over grass ) ,at this point the Battery could just die at any time , then as it gets lower in power I stay just skimming the deck until the battery dies, then I let battery cool and recharge.
Just make sure you are with 20 meters of the Home Point and the RTH will not engage .
You could also change the settings to Hover Or land Etc. the prblem here is you may forget and when you need the RTH for real, it may just be hovering a Mile away......
donnie
