imaginewizard
Hi,
So I was about to take my DJI Phantom 3 Standard flying but noticed that the back right propellor wasn't spinning (though it was rotating), even though I had tightened it on, and all the other propellors were fine.
Here are the observations I've made:
- I've changed the propellor to opposite one, which is working, but the same error occurs, leading me to believe it's not a fault with that propellor.
- If I tighten the propellor, the whole rotor doesn't spin as fast as the other rotors.
- If I place the propellor on loosely while the rotor is stationary, or if I rest the propellor on an already spinning rotor (so that it tightens when I start the rotors spinning), the rotor AND the propellor will spin at the correct speed - however when I increase throttle for take off, the propellor will spin off the drone. So basically if the propellor is hand tightened, it won't spin quickly, if I place it on loosely so that it tightens itself, it will fly off when throttle is increased.
This leaves me at a bit of a loss as to what the fault is. Has anyone experienced this before?
Thanks very much,
