kstrysick
Costa Rica
Hey everyone, I just bought an Inspire 1 updated as required and we experienced the same issue with the gimbal not being horizontal. IE video was not level and looked like the camera was at about a 5 degree off of level.
I am an experienced pilot with well over five hundred hours of fly time with several types of drones including servicing them. In fact, we use them to survey mining sites throughout North, Central and South America. I am also an Engineer.
The documentation DJI has provided is enough to make the novice very dangerous and gives us experienced pilots no comfort the product is being sold without complete and thorough caution and proper training. No matter what you think, these are not toys. The most important part of flying is the drones position in relation to you. If you lose your camera due to a malfunction the number one rule is fly the drone based on the data it provides you. IE altitude, distance and direction all of which is provided in the pilot app.
What we found is as follows; when you calibrate your IMU, you have to do it on the most level surface possible. If you perform this operation on a surface that is a couple degrees off the gimbal will calibrate to that off positioning. Get yourself a level and make a surface such as a small table and make it as perfect as you can. Then initiate the IMU calibration. Then on the same surface calibrate the gimbal. We found this to be a major stop gap measure to the issue of gimbal to drone positioning in the whole calibration process.
