Phantom 3S Weak RC signal problem (After 1.6.8 update) POSSIBLE S...
2367 14 2016-6-25
imdilanvlogs
Sri Lanka
As you guys know, I was so desperate after 1.6.8 firmware upgrade and I was loosing RC signal within 40m-60m .. But After 1.5 months finally solved it permanently.. Here we go!!!
In my method, Basically you need to put 1.6.80 firmware to your RC and also you need to put 1.5.70+ to aircraft. so How do we do that?>???
1. You need upgrade your drone using LATEST DJI go app.  ( if you are already in 1.6.8, then downgrade it in to 1.5.7 )
2. After upgrading to 1.6.8 please close DJI go app, restart the drone and RC connect it, after that Switch off all the      things.
3. Then download and put 1.5.7 firmware bin file to a SD card.
4. Put the SD card in to the aircraft WITHOUT turning it on.
5. Then turn on the aircraft WHILE PRESSING RC LINK BUTTON ON THE AIRCRAFT LEFT SIDE BODY.
6. Hold it on for like 20 seconds and release it.
7. Then complete firmware upgrading process will start and it will be over within 10-15min as usual..
8.Then restart the drone.
9.After all these steps your RC will be stay in 1.6.8 and your aircraft will be 1.5.7+ and DO NOT UPGRADE AGAIN, unless you want the problem again.. LoL...
Have a flight and PLEASE DON'T FORGET TO COMMENT THE RANGE YOU GOT!!!!!
[size=14.6667px]PS: And finally thanks you my friend "mpogrebnoy" ( from US ) for showing me that game changing screenshots ..
2016-6-25
egconstruger
Flight distance : 26906 ft
Dominican Republic
mmmm, well i have tried like 104004040 different things and still got same result,  i will try this one is something new( i hope this really fix it) lol will let you know tomorrow
2016-6-25
imdilanvlogs
Sri Lanka
egconstruger@gm Posted at 2016-6-26 09:22
mmmm, well i have tried like 104004040 different things and still got same result,  i will try this  ...
I was exactly like you bro.. tried everything and finally found this.. Give it a try..   and for the record I was loosing RC signal NOT the video signal..
2016-6-25
imdilanvlogs
Sri Lanka
2016-6-25
haavargu
Flight distance : 7219669 ft
Norway
Hi, I have exactly the same problem... video link is ok but I lose RC signal very quickly, sometimes at 20m, sometimes 120m.. I could go 350m before - no probem (same area). I tried your solution, but it didn't help me Is DJI aware of this probem and will they fix it in future firmware, or is the only solution to send it to DJI for service?
2016-6-26
a.romero.vaquer
Hi, I have exactly the same problem. Thanks for provide this method , but it has not worked this to me.
Regards
2016-6-26
mpogrebnoy
Hey imdilanvlogs, gald you get improvement. What's your range now? I still think that the major problem is not the SW version per se but the fact the updates easily can go vexed and require re-linking. As my typical max range is 50% against of my friends' identical unit, I feel itch to send it to DJI in CA to make my mediocre unit a good one.
2016-6-26
bradleybowers
Flight distance : 643360 ft
Brilliant! But where do I download the 1.5.7 firmware from?
2016-6-26
egconstruger
Dominican Republic
hello, i just tried that. no luck at all , still have signal lost at 35m , seems we are limited to 35-40m now.... lol
2016-6-26
egconstruger
Dominican Republic
Please, change the titlte of this post, if moderator see it they will think problem have been resolved and then contact dji support team and they might not release a fix for this
2016-6-26
haavargu
Norway
Well, I got my P3S back from DJI Netherlands rapair center yesterday and tried a testflight today, but the problem remains the same... maybe a little worse... Tried relinking RC, but it's the same... I am so disappointed right now.
2016-7-19
rellinb
DJI-Ken - is there anything you can offer on this issue in terms of DJI's awareness of the P3S RC Lost reports and any work that may be going on to resolve the issue?
2016-7-19
Gstan30117
Flight distance : 228645 ft
What is the link to down load fw updates?
2016-8-20
Gstan30117
So today I tried again to down grade FW again and now I can't link the drone and the controller. I tried the manual link but the link light on the drone is not flashing and still won't link. Is there anyway to clear all firmware from the drone and re-install? Or if anyone has any other suggestions to get me past this.
Thanks
2016-8-21
Gstan30117
Gstan30117@hotm Posted at 2016-8-22 03:16
So today I tried again to down grade FW again and now I can't link the drone and the controller. I t ...
Never mind, I got it.
2016-8-21
