OSMO X5 + Follow Focus? How to mount?
1696 8 2016-7-13
ariajalali
Hi guys. Just got a Follow Focus from DJi, looks cool. Have an XR mounted on an OSMO.
Just curious to know - how do you guys mount this thing? I see it has an OSMO-ish attachment hole on the back, but what screw do you use?
Any thoughts? Thanks!
Aria
2016-7-13
DJI-H.C
Flight distance : 13602 ft
Hi, does this guide help? https://dl.djicdn.com/downloads/ ... Guide_160203_en.pdf
2016-7-14
rj74
the X5 adaptor has 2 mount points, back one for the phone holder, front for the focus, you just fix with the mount point on the back of the focus
2016-7-14
ariajalali
Yes but how do you attach to the front one, mine did not include a screw?
2016-7-14
DJI-H.C
ariajalali@gmai Posted at 2016-7-15 00:33
Hi, you don't need extra screws, they will fit
2016-7-14
ariajalali
I am not sure I have that one, is it possible to buy replacement screws?
2016-7-19
ariajalali
Also, once I mount the phone and this focus, is it possible to still mount the Rode microphone?
2016-7-19
DJI-H.C
ariajalali@gmai Posted at 2016-7-19 04:24
It's strange, your X5 adapter looks different from the one in #5?  The screw can not be separated from the adapter. Where did you buy it? Contact the seller.
2016-7-19
dopeytree
Flight distance : 6716467 ft
See my post here: http://forum.dji.com/thread-55499-1-1.htmlIt shows my setup.
To mount the mic you will probably need to buy some accessories. it should still work with the quick release mic bit. I would also advise buying the one that gives you 2 accesories screw ports
2016-7-19
