A3 Setup: Is this an Error
1081 6 2016-7-20
apost
Flight distance : 1842283 ft
Trying to get the A3 up and running and see what looks like an alert/warning logo beside both IMU and Compass.  See the attached photo.  Is this telling me there is something wrong or just that I have not calibrated yet or something else???
2016-7-20
brich12003.yaho
Looks like just calibration is needed make sure you are using newest  assistant version released a couple weeks ago
2016-7-20
DJI-Jamie
Flight distance : 112405 ft
I concur with Brich. In addition, you should be able to click on the warning ico as well in order to get more info on the error message.
2016-7-20
apost
When I click on the icon...it just goes to a diagram that confirms either A3 or A3 Pro gear is connected.  But each piece of hardware is outlined in Red.   Is THAT a warning, or just a pretty color in China?
2016-7-21
DJI-Jamie
apost@andypost. Posted at 2016-7-21 21:24
When I click on the icon...it just goes to a diagram that confirms either A3 or A3 Pro gear is conne ...
This seems to reflect a calibration issue based on your description, but if you could provide more screenshots on what you're seeing, it would be very much appreciated. Have you tried calibrating these components?
2016-7-21
ftimster
Do you only get this screen if your using the a3 pro I don't get this screen in the new assistant software?
2016-7-21
DJI-Jamie
ftimster@hotmai Posted at 2016-7-22 13:00
Do you only get this screen if your using the a3 pro I don't get this screen in the new assistant so ...
It should be common for the A3 and A3 Pro. Could you provide a screenshot of what you're seeing? To clarify, you are using a standalone A3 system and not a M600?
2016-7-21
