Landing gear issues after a crash
915 4 2016-7-23
atfjan
Flight distance : 195748 ft
I was flying at night well out of view above traffic to get some long exposure light trails. When returning to home I hit a telephone wire and the bird dropped about 30 ft. Can't blame that one on a firmware update. Broke two props and cracked the front two secondary arms but not completely severed. I repaired the arms with fiberglass tape and resin and now as sturdy as new. Made several flights since and everything is working perfect except after about 2 to 3 minutes into a flight the landing gear slowly creeps down about half way. I manually lower then raise the gear via the RC and it stays up for a few minutes then lowers again. It raises up fully on takeoff and lowers on landing so it doesn't appear to be any binding. Any ideas on this?
2016-7-23
Donnie
Flight distance : 3636782 ft
Sounds like the worm gear is stripped on the main spline for the landing gear or the servo motor gears are stripped on the landing gear servo.  I would expose the screw from the protective boot and see if there are any shavings from striped gears.
It will need a tear-down, if you are handy then go for it , or just send it in.  If you choose the former - I have found when taking thinks apart that video and pic's are priceless, also label all wires and connections.
good luck
donnie
2016-7-23
atfjan
Donnie Posted at 2016-7-23 15:04
Sounds like the worm gear is stripped on the main spline for the landing gear or the servo motor gea ...
Thank you Donnie. Not a fan of being without it for weeks so I'll dig into it. Spent 40 years as a machinist and professional tinkerer. Yep, I take pics of most disassemblies.
2016-7-23
RichJ53
Flight distance : 1837356 ft
atfjan Posted at 2016-7-23 13:49
Thank you Donnie. Not a fan of being without it for weeks so I'll dig into it. Spent 40 years as a ...
Could be the motor or circuit board for the gear too.  you may decide to replace the center part yourself ... here is the link for a new center section
http://www.ebay.com/itm/DJI-Insp ... :g:-UIAAOSwnLdWsmsx
Rich
2016-7-23
Donnie
atfjan Posted at 2016-7-23 15:49
So not your first Rodeo ........
Have fun
donnie
2016-7-24
