No video feed
749 5 2016-7-23
PartsGuy
Flight distance : 418346 ft
I bought a new battery and recieved it yesterday. I charged it up and put it in my P4 to make sure the battery firmware was up to date. I turned the P4 on and it flashed the lights for about 2 minutes and the gimbal light turned green. I turned it off and connected my mini 4 to the controller, turned on the P4, then the controller and then brought up the DJI Go app. As soon as I opened the app, it said inconsistant firmware and asked if I wanted to update. I selected yes and after about 3 or 4 minutes it said update was successful. Tapped on the camera icon and I checked everything out.  Everything was fine but I had a black and white still picture on my screen and no video. I took it outside and started everything again. Same thing. Fired it up and flew about 30 feet away. I can control the gimbal but nothing but the B/W thing on my screen. No error messages. Any ideas?
2016-7-23
Heebus
Might wanna try re installing the app... just a thought, sometimes it works tho
2016-7-23
PartsGuy
Panic for nothing I hope. Refreshed the firmware using Assistant 2 and deleted and reloaded the Go app. I've got video to my ipad mini now. I have to go over the settings and reset those. Too hot to fly now will try this evening when it's cooler and see how it flies.
2016-7-23
DJI-Paladin
Flight distance : 2408 ft
Hello PartsGuy, if the issue still exists, feel free to post it here with some screenshots and video clips.
2016-7-24
PartsGuy
DJI-Paladin Posted at 2016-7-25 01:19
Hello PartsGuy, if the issue still exists, feel free to post it here with some screenshots and video ...
Thanks for checking Paladin. I flew this morning and all seemed fine. Went out about 400 feet and up about a 100 feet. Good reception to the ipad with no signal dropping.
On edit: Just a quick question about obstacle avoidance. I also checked it this morning. I flew it at a brick wall slowly about 6 feet agl. At 7 feet it started beeping and at 6 feet it hovered. Does it compensate for the approaching speed and compute the distance from the obstacle to bring it to hover at a safe distance? At full speed for instance, it might take more than 6 feet to get stopped and hover.
2016-7-25
DJI-Paladin
PartsGuy Posted at 2016-7-25 20:45
Thanks for checking Paladin. I flew this morning and all seemed fine. Went out about 400 feet and u ...
It depends on its speed.If it is at full speed, it is necessary for leaving enough safe distance for break.See it here: 000.JPG
2016-7-25
