P4 Camera will not Tilt
688 4 2016-7-23
osjoe2
Flight distance : 106926 ft
DJI GO App 2.8.2
P4 Firmware is on latest .503
Calibrated gimbal and IMU/Vision sensors. Have also tried resetting to factory settings with DJI asistant 2. When trying to use the camera dial on the RC the camera will not tilt at all. It has been working fine since I first got the P4 3 weeks ago but today all of a sudden I cannot get it to work. I can however hit the left button on the bottom of the RC which will drop the camera facing straight down and then back to level, there is no in between anymore.. If have not had any crashes or anything experiences that would have damaged the bird. Any suggestions?
2016-7-23
Heebus
Check RC controll settings, maybe you/ or the update changed what that button does...
2016-7-23
osjoe2
Heebus Posted at 2016-7-23 16:28
Heebus,
thanks, your post made me go deeper into the menu settings. I needed to go to Ginbal settings > advanced settings and then reset those settings. It seems to be working fine now.
2016-7-23
Heebus
yes sir, I think once in a while its a good idea to check these settings, especially after a upgrade in firmware... things can be set back to factory, and not a good time to find out when your in the air!
glad you figured it out... happy flying
2016-7-23
DJI-Paladin
Flight distance : 2408 ft
Hello osjoe2, have you tried to calibrate the RC? If it is convenient, you can link your P4 and other RC to test the camera:
2016-7-24
