What is causing this video drop-out?
12
4820 52 2016-8-8
sthuemmel
Flight distance : 1749321 ft
QuadBart Posted at 2016-8-13 11:15
Okay Update 20160813 -  As mentioned I did all the above and took it out for a flight this morning.  ...
What is Update 20160813?  Is this the IOS/Android app? or Inspire firmware?
thanks,
2016-8-13
GabeZ
Flight distance : 768448 ft
I didn't get to fly..... Precipitation too high
2016-8-13
RichJ53
Flight distance : 1837356 ft
QuadBart Posted at 2016-8-13 08:15
Great, thanks for reporting back to us
Happy flying
PS you can see the results of my DJI  repair experience posted yesterday.
http://forum.dji.com/thread-60733-1-1.html
Rich
2016-8-13
GabeZ
QuadBart Posted at 2016-8-13 09:15
I had to make a transforming pad for mine.  Travel mode has a rough time with anything other than a same color, semi gloss surface.  I would suggest you make one as well.  Those plastic feet will end up getting scratched snd scared if you transform it on the ground.  I bought 3D printed skids to protect the plastic feet on mine.
2016-8-13
QuadBart
Flight distance : 256506 ft
sthuemmel Posted at 2016-8-13 10:18
thanks,
Oh thats the date in which I performed the "re-test".  Its not related to anything Firmware related or DJI related...
Remore, Inspire, DJI GO app on my Ipad are the latest as of that date...
2016-8-13
cgooge0
DJI-Jamie Posted at 2016-8-11 01:29
I just wanted to check to see if this occurs while auto hopping from channels or if it occurs from ...
This is happening for us when on auto channel hopping. Selecting a channel stabalizes it to a degree
2016-8-16
cgooge0
chris91111 Posted at 2016-8-12 08:12
I got poor signal strength for video after doing the RC firmware update.  Had to downgrade because i ...
Did that fix your issue?
2016-8-16
Jason 2015
Flight distance : 292300 ft
Same issue started after the last firmware update.  Image drops out and screen goes green.   4 minute video consists approximately 4 to 6 still images.   I1P also is considerably less steady even with 14+ sat locks.  Will not be flying again until I get this resolved.
2016-8-16
cgooge0
Just downgraded the firmware back to 1.6 and the video cut outs have stopped....
2016-8-17
DJI-Jamie
Flight distance : 112405 ft
cgooge0 Posted at 2016-8-17 04:11
This is happening for us when on auto channel hopping. Selecting a channel stabalizes it to a degr ...
Is your transmission bitrate set at the highest setting or is it low?
2016-8-17
GabeZ
DJI-Jamie Posted at 2016-8-17 15:32
Correct me if I'm wrong, but when you switch to auto, you lose the ability to choose bitrate.  I thought that setting was only available in manual mode.
2016-8-17
RichJ53
GabeZ Posted at 2016-8-17 17:46
Correct me if I'm wrong, but when you switch to auto, you lose the ability to choose bitrate.  I t ...
hey gabe
you are correct, this adjustment in only in manual mode, not in auto. I don't think it is a sticky control that holds in both modes
Rich
2016-8-17
GabeZ
I've got a feeling the issue is actually in the firmware of the aircraft and not in the go app or firmware of the RC.  The reason I say that is because I started to notice this after the whole epidemic of crashes with the last firmware.  Back then, I was still using 1.6 for RC, an IPhone 6 Plus, the latest go app at the time, and the problematic aircraft firmware.  None of my settings really changed (I'm simple... if it works, it works).  However, one key difference is that the preview was occasionally blanking out and recovering as opposed to getting stuck in a constant flicker of black and green.
2016-8-17
12
