Donnie
Flight distance : 3636782 ft
There is something binding the Stick , ( Thanks donnie , Captain Obvious ) if you feel up for it very gingerly remove the back panel ( Instructions on you tube for changing antenna ) Once you get in there you may find a stray wire rubbing against the stick spring or it may be a broken plastic part holding the spring. If you have just a little bit of technical know how I would do the surgery, just take lots of pictures during the procedure to remind yourself during re- assembly and go slowly.
donnie |
