Cetaman
Flight distance : 2528264 ft
Aloha cox,
Sorry, you are combining the waypoints benefit with the much easier POI. Your best option, in a pitch (pinch), is to wait until between innings to set your center and then pull your radius. If you are quickly setting your center, there is reduced probability of flying over people since they are supposed to be off the field at that time. Check with the head official before the game so you can work with those on the field to keep safety first. The path you take to pull your radius can be determined by the least likely location of players as they replace each other during the between innings hiatus.
Your circular path will be way outside populated areas of the field and stands. Be sure to mention that to the umpire in charge (head official). Since your priority will obviously be safety first and their priority is safety first, you should be able to find common ground. You all want the exposure that a flying camera can provide.
Hope this helps!
Aloha and Drone On! |
