Geebax
It has nothing to do with the SD card, and everything to do with the locality where you are flying. The Standard is notorious for short range, and you need to be in an area where there is no competing WiFi signals.
Are you flying in an urban area or in the countryside? Also make sure you are pointing your antenna correctly, above your head is the worst place for losing signal. |
