Kaiphoenix13
Philippines
Updating the battery is also same as updating the firmware . When you do firmware update the battery, esc and imu are also updated . Simply to say all you need to do if you've already done updating the drone before and the bin file is still in the sd card all you need to do is connect the new battery and do upgrade will be initiated automatically |
