Received a defective Osmo Mobile
3223 16 2016-9-7
rossmedia
Flight distance : 77946 ft
I just received a defective Osmo Mobile - Unfortunately the gimbal motors do not seem to be functioning.  After balancing the phone and turning it on and connecting to the DJI Go app via bluetooth, the phone does not seem to move at all.  The app says, "Device Positioning Error. Turn off device and reposition as indicated" - even though it is positioned correctly.  Sent a note to support and waiting for a response.
Bummed!  I ordered immediately when it was annouced with the hope to use it for an event this weekend.
2016-9-7
DJI-Ken
Flight distance : 1515312 ft
You activated the battery correct?
You need to fully charge the battery before powering it on and then you have to activate it.
You can test the unis without a phone, if you hold your finger over the photo sensor it should still stabilize somewhat.
If you have gone through all the activating steps, then the only Osmo Mobile I've ever seen not stabilize is when the phone has a aftermarket wireless charging back cover attached to the phone. I took the cover off and it stabilized immediately.
Here's a video of the activation process.
2016-9-7
rossmedia
DJI-Ken Posted at 2016-9-7 15:59
You need to fully charge the battery before powering it on and th ...
Thanks for your response!
Yes, I fully charged the battery and activated it.
I discovered that with the Apple branded Silicon Case with my iPhone 6 on (Grey in color), it does not stabilize.  Without the case, it's fine!  I also placed a piece of tape on the back of the case, then it seems to stabilize.  Perhaps the phone detection does not work well with that case.
2016-9-7
DJI-Ken
rossmedia Posted at 2016-9-8 05:09
Ok, thanks for letting me know. Like I said the only case that did not work was an aftermarket wireless charging case.
I'll add this one.
I don't know what's making it not work. But it's good that we know the Osmo is fine.
Enjoy it.I'm going to edit your thread topic.
2016-9-7
DJI-Thor
Flight distance : 13602 ft
Hi, sorry about your experience.  You can make do with the tape for now and a later firmware might add options to ignore/disable that detector.  You're welcome to share some videos you shoot with your Osmo Mobile
2016-9-7
rossmedia
DJI-Thor Posted at 2016-9-8 15:21
Hi, sorry about your experience.  You can make do with the tape for now and a later firmware might  ...
Thanks, disabling the detector as an option would be helpful!  Thanks for reviewing.
2016-9-8
rossmedia
DJI-Thor Posted at 2016-9-8 03:21
Here is a my first test shot with an iPhone 6 & DJI Osmo Mobile.
So far I'm happy with the results from such a Gimbal, better than other phone gimbals I've tried.
2016-9-8
DJI-Thor
rossmedia Posted at 2016-9-9 10:30
https://vimeo.com/182032340
Good to know
2016-9-8
DJI-Ken
Very nice video, glad you are enjoying your new DJI product.
And glad it is working better than the other phone gimbals you have tried.
2016-9-8
Kaleidoscope74
Flight distance : 977500 ft
Switzerland
Same here... I just got the Osmo Mobile and to my surprise, it doesn't work with my grey silicon OEM case from Apple. Without the case it works flawless.
@ rossmedia, can you explain where you put a tape on? Thanks!!
2016-9-9
SoNiK
Flight distance : 183248 ft
@Rossmedia
Great video...really
2016-9-9
rossmedia
Kaleidoscope74 Posted at 2016-9-9 15:49
Same here... I just got the Osmo Mobile and to my surprise, it doesn't work with my grey silicon OEM ...
Sorry for the delay - here is the info if you haven't figured it out.
2016-9-14
derekoneill99
I also had a problem with the osmo recognising my phone, so I put a piece of black tape over the sensor and it's working now.
2016-9-14
MicroFPV
rossmedia Posted at 2016-9-8 21:30
Your video looks pretty good for phone video.  I'd love to see some short samples from someone, anyone, that can show before and after of some short scenes.  Something that shows how normal hand held phone video looks in comparison.  I am new to the Osmo stuff and just trying to educate myself on it's usefulness and decide if I need the Osmo mobile or not.
Also, what other brands have you tried if you don't mind sharing your time and experience.  If you don't want to list any of this here you can mail me at microfpv@gmail.com.
Thanks!
2016-9-15
DJI-Thor
rossmedia Posted at 2016-9-14 08:15
Well, you can paste that on the gimbal instead of on the phone case, so you can keep the paper there, until there's an update of DJI Go.
2016-9-16
DJI-Thor
MicroFPV Posted at 2016-9-15 17:00
Your video looks pretty good for phone video.  I'd love to see some short samples from someone, any ...
You can check this, at 4:10.
There are a few competitors of Osmo Mobile, but I can assure you none of them performs as good in terms of stabilization. There are some comparison videos on Youtube.
2016-9-16
skay
Flight distance : 31932 ft
Your on-line chat tech support folks could use this information. I had to point out a similar thread today, after the tech said that my gimbal was defective because of taping the sensor--and yes, my gimbal really is defective, but for vibration during stabilization. RMA is in process.
2016-9-21
