ground station autonomous flight with lightbridge
6050 19 2014-9-29
geoffreysblack
Can you program way points with the groundstation into your phantom 2 for autonomous flight while using the lightbridge. It says in the DJI Q&A somewhere that the 2 units using 2.4 ghz will conflict. My question is if the flight was preprogramed & autonomous, then after sending the drone on a mission the groundstation is no longer transmitting??? Is this a correct assumption?
2014-9-29
DJI-neil
Flight distance : 13465 ft
China
2014-9-29
andersonpaac
Don't use the 2.4 ghz with datalink , won't work
2014-10-15
Tahoe_Ed
Flight distance : 2605 ft
While it may be possible, it is not recommended.
2014-10-15
dji
United Arab Emirates
It is not recommended due to interference or some other reason?
2014-10-17
Tahoe_Ed
There is potential interference between the wifi connection on 2.4gHz and the Data Link also on 2.4gHz.  That is why it is not recommended.  DJI please change your user name as it may be confused with DJI employees.  Thank you for your assistance.
2014-10-17
dji
I would like to change my username (it simply took the first part of my email address) but I don't see how to do it -- please provide a link so I can change my username
Thanks!
2014-10-17
maxisteve
Flight distance : 51677 ft
i have used the 2.4 datalink with the lightbridge and it will NOT work. Throughout the flight , i either lost signal to the datalink or the lightbridge and this is because both use the 2.4 frequency. What you can do, however, is use the 900 mhz datalink, the 900 lk. I have also used this and it works no problem, different frequency and all. You have to get used to the , not so friendly, user interface with the PC rather than with your ipad.
2014-10-17
chris
Indonesia
sorry its crap.. upload your data from waypoint and when it starts to the first point swith off the gs on ipad and on LB.. its working just fine..
2014-10-26
hvilorio
Flight distance : 10184222 ft
Dominican Republic
I have tried to find the 900 MHz version (PC ground station) and nobody seems to have it in stock... I really need to use GS and LB together... Is there something coming down the pipeline that would maybe work together? I'm flying an S900/A2/GH4/LB.
2014-10-29
martinjm1
Flight distance : 332559 ft
Peru
LB is actually a Data link (I'm wrong?). I think DJI could release some sort of upgrade (maybe sw and hw) to fly autonomously with the LB
2014-10-31
justin.rose
Just use the 900 Mhz model and it will work great with LB. The only downside is that you have to use a PC instead of an iPad.
2014-11-3
T J Gilbert
Flight distance : 74659 ft
dji@samy.pl Posted at 2014-10-18 12:16
I would like to change my username (it simply took the first part of my email address) but I don't s ...
To change Username:
Go to DJI.com (click on top left of screen)
At DJI.com, log in (click on Log In at top right of screen)
You should be logged in already...
Go to your account settings, select edit your profile, and change your user name
2014-11-4
andersonpaac
chris Posted at 2014-10-27 12:28
sorry its crap.. upload your data from waypoint and when it starts to the first point swith off the  ...
Have you actually tried this , I am considering doing the same!
2014-11-4
chris
Indonesia
andersonpaac@gm Posted at 2014-11-5 07:16
yes i did and it work fine.. only problem you cant follow ph2 on ipad..
2014-11-5
andersonpaac
chris Posted at 2014-11-6 11:56
Thanks Chris! Were you able to follow with the iPad if you had the LB off? (vice-versa?)
2014-11-9
chris
Indonesia
never tried, sorry
2014-11-10
ducpeter
Flight distance : 62175 ft
is there any update coming for the A2, LB and datalink 2,4GHZ
on the Inspire it look like it work together, every customer from S8/9/1000 with A2 and LB will be happy
2014-11-24
livethrive
ducpeter Posted at 2014-11-25 06:33
on the Inspire it look like it wor ...
What is the word DJI? Now that I paid thousands for the lightbridge why can't i program way points with it?
2015-1-10
tiagoferreira.p
Portugal
Hello,
I have my Lightbridge, only to transmit hd image from gimbal camera, not to control the drone (for that i have my A2 with graupner GR-24 receiver).
So my question is, can i use LB with the 2.4 GS using the LB only for video?
2015-1-30
