Ronin m pans back and forth on its own
1316 7 2016-9-15
medavidson
Balanced the camera turned it on. After a moment, the ronin-m starts to pan back and forth, like this:
Rebooted, reset, etc. same thing.
You can reach out with your hand, steady it and it will be fine for a minute or two...  then it does it again.
Any ideas?
2016-9-15
DJI-Jamie
Flight distance : 112405 ft
Try a gimbal calibration if you have not done so already. If the issue persists, then a repair service would be the best course of action.
To clarify, is this an out of box issue, or did you notice this after a firmware update or long term storage?
2016-9-15
medavidson
DJI-Jamie Posted at 2016-9-15 17:26
Try a gimbal calibration if you have not done so already. If the issue persists, then a repair servi ...
This is not a brand new Ronin-M.  We have used it for a few months.  We had used it without problem a few days earlier.  We will go through the gimbal calibration.  Thanks for the info and I will report back.
2016-9-16
DJI-Jamie
medavidson Posted at 2016-9-16 19:37
This is not a brand new Ronin-M.  We have used it for a few months.  We had used it without proble ...
Please keep me posted.
2016-9-16
medavidson
I think I need to RMA this.
We have recalibrated / reset all and the problem persists.
Also -- we have now noted that neither the wireless thumb controller or the pan and tilt remote no longer control the ronin M at all.   Can you help get an RMA started?
2016-9-21
DJI-Jamie
medavidson Posted at 2016-9-22 03:30
For the thumb controller and the RC, are they up to date with the latest firmware as well? Unfortunately I'm unable to start a Repair ticket, you would need to either email support.us@dji.com or call
+1 818-235-0789 to get that started.
2016-9-21
medavidson
DJI-Jamie Posted at 2016-9-22 06:25
For the thumb controller and the RC, are they up to date with the latest firmware as well? Unfortu ...
Hey Jamie-  Thanks for the info.  I will open a support case.
Mark
2016-9-21
DJI-Jamie
medavidson Posted at 2016-9-22 07:48
Mark
Thanks for the update, you will be up and running again in no time.
2016-9-21
