Donnie
Flight distance : 3636782 ft
When you initially fire up the system does the aircraft camera go through the normal dance sequence ? This is an Inpire 1 with the X3 camera correct with One controller ?
Do you have Control of the Aircraft ? Can you start the motors for example . In the header you say No control but in the Post its says you have contol ?
If you have No contol of the Aircraft that would indicate the NO SIGNAL , that would tell me you updated the RC and Not The AC
Did this happen immediately after an update or anything ?
On the top of the screen next to DJI logo far left , where it would usually say "SAFE TO FLY " OR "DISCONNECTED ' what does it say ?
Do you have a good cable from the Go App to the RC ? A good way to check is to go to Remote Control Tab on the GO app of you can see the "Master" " Slave" 'Off" options page then you have a good connection between the RC and The Go app Device .
Go to the 'about " tab under general settings and are you up to date on the Camera, Aircraft, RC ? could you please list them. AC, RC, Camera, Go App version
I need more infomation and clarifiacation . The Go app "About " page is crucial and did this occur after an update ?
donnie
