I’m on my 3rd new battery / 2nd new charger with the same issue. I plug in the P4 battery for the first time, and the power LED comes on, then the 4 LED’s blink. The lowest level LED blinks at about a ½ second rate for about 5 seconds, then changes to 1 second blink rate, and blinks about 3 times, the goes out, and will not take a charge. The first one was a new P4 from Best Buy, and DJI support said to just return the whole package for new one. The replacement worked fine. I just received 2 new batteries from BB, and they both have the same issue described above. I have tried to power on and plun in to the charger,but no change. I tried installing the battery in the bird, to connect to Assistant, but will not connect. Any ideas?
