Z15-GH4 Gimbal Reset camera pointing down.
960 9 2016-9-27
Saffron96
Flight distance : 80466 ft
Hi
I have mounted a Light Bridge 1 to my s900 using Wookong M Flight Controller and Futaba T8J
When I set the thre position switch to RESET the camera FPV position is vertically down and not forwards. Is there a simple fix for this?
Thanks
2016-9-27
DJI-Jamie
Flight distance : 112405 ft
To clarify, is the gimbal in a downward tilt motion when you hit reset?
2016-9-27
Saffron96
DJI-Jamie Posted at 2016-9-27 23:14
No. it will reset to point down from any position when I select RESET
2016-9-28
dennismurry08
Flight distance : 5948264 ft
Its been awhile but if I remember right check the assistant..I believe it gives the option of downward or fpv for reset.
2016-9-28
Saffron96
dennismurry08@c Posted at 2016-9-28 17:31
Its been awhile but if I remember right check the assistant..I believe it gives the option of downwa ...
Which assistant would that be Dennis?
2016-9-28
Saffron96
2016-9-28
Saffron96
Saffron96 Posted at 2016-9-28 21:33
Just found the relevant page of the Gimbal manual. However it refers  to setting a two way sŵitch on the Futaba and wiring the relevant Chanel of the receiver  to AUX2 . I am using Light Bridge 1 so there's no receiver other than this in the circuit. Is there a work around for this do you know?
2016-9-28
dennismurry08
Saffron96 Posted at 2016-9-29 04:43
Just found the relevant page of the Gimbal manual. However it refers  to setting a two way sŵitch ...
I believe it was the Zenmuse assistant...I have a 3 way switch on my  Futaba 14 for it on LB-1 ..its FPV (forward reset) Free (I think that was the name of it) where you can pan etc and and down..like I said it's been awhile since I've been in there but its there someplace...it may have been just changing the AUX wiring...I dont have it with me or I'd plug it in and double check for you. If you dont find the problem I'll check when it comes back..its out on a film and hopefully they finish Friday night. Also I do know that when I use the reset or FPV switch I can't use the pan/tilt etc...I have to change the switch to "free".
2016-9-28
DJI-Jamie
Saffron96 Posted at 2016-9-28 16:50
Do you have your AUX channel for FPV reset as a 2 channel or a 3 channel switch?
2016-9-28
Saffron96
dennismurry08@c Posted at 2016-9-28 23:39
I believe it was the Zenmuse assistant...I have a 3 way switch on my  Futaba 14 for it on LB-1 ..it ...
I have a 3 way switch set as you refer FREE/ RESET/ LOCKED but am not sure how to go about setting a two way switch on my Futaba to change the RESET camera position to look forward in stead of down. I'm a bit of an amateur and the 'radio set up' thing for me is somewhat challenging. I am going to have a closer look into seeing if I can tune a 2way switch to AUX 2 as suggested by the Zenmuse manual.
2016-9-28
