Crashed - Need Advice
624 4 2016-10-4
Wingsy
Crashed into a tree, fell through the limbs to the ground. Has 4 fractured legs. No other apparent damage.
But before I go trying to snap the legs back into place I'd like some advice on what I can/should do and what not to do.
Can I just apply pressure to the long separated areas and they will pop back into place?
Looks like the small pop out tabs (where you can see one is missing) need to be removed before the legs can pop back into place. True?
And how do I snap the tab out? And how do I put it back?
If anyone can offer some advice here I'd appreciate it. I'd rather learn from you than to take an expensive lesson from myself.
2016-10-4
Warnberg
Flight distance : 24764 ft
http://www.dronenerds.com/produc ... 6-p4part26-dji.html
Replace them... FYI I am not associated with dronenerds at all, just did a quick search and for 29.00 I'd just get new and replace them
2016-10-4
stymo
Flight distance : 499160 ft
Tape works fine until you can replace.
2016-10-4
hallmark007
Flight distance : 9827923 ft
Looks like lucky escape, I think you can put it back together temporary and yes looks like small tabs would be last to go on,as above has said if it doesn't work $29 for new legs.
2016-10-4
DJI-Jamie
Flight distance : 112405 ft
Yes the tabs for the screw covers would be the last thing you would need to put back when replacing the landing gear. Please keep in mind, however, that there can be some antenna damage that will affect the overall flight or image transmission in the future. You may want to have the unit sent in for service.
2016-10-4
