BEEP BEEP BEEP BEEP BEEP BEEP Non stop second remote
5851 6 2016-10-14
Vortex Drone Se
Flight distance : 21296 ft
This is nuts!
i am on location to do a shoot. My second remote (slave) goes Beep Beep Beep  Beep Beep Beep  Beep Beep Beep  Beep Beep Beep Beep Beep Beep  Beep Beep Beep  Beep Beep Beep  Beep Beep Beep Beep Beep Beep  Beep Beep Beep  Beep Beep Beep  Beep Beep Beep Beep Beep Beep  Beep Beep Beep  Beep Beep Beep  Beep Beep Beep Beep Beep Beep  Beep Beep Beep  Beep Beep Beep  Beep Beep Beep .
I just wanted to emphasize the annoyance of the situation.
A few times if I press both sticks up it stopped But not after the upgrade.
It shows the remote connected BUT the aircraft is disconnected
Any idea how to solve this problem.
Thank you for your help
2016-10-14
RichJ53
Flight distance : 1837356 ft
vortex
The Beep Beep Beep was telling you that the remote needs calibration. I have had this happen too. The fact that you have updated the FW now on top of the first issue might have thrown another problem on top of it all.
1) calibrate the remote, watch this video and it is the same procedure for the Phantom and Inspire remotes
2 If you have the slave remote on your master saved;  delete it from your master controller and set up the slave remote again using the procedure  video below
If it doesn't work then downgrade the FW on the remote and then recalibrate it again.  I hope you understand my rambling and this helps you.
remote calibration
Setting up the Master and Slave remote videos
Downgrading the remote Firmware
Linking to the aircraft
Calibrate the IMU and compass
Rich
2016-10-14
Donnie
Flight distance : 3636782 ft
ditto what Rich  said !
donnie
2016-10-15
DJI-Jamie
Flight distance : 112405 ft
If the issue persists after Rich's advice, please try the following button combination to reset the RC:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
This will allow for you to set the RC as the slave again. You can also calibrate the RC for good measure.
2016-10-15
Vortex Drone Se
Thank you. All is well .
Much appreciated the support
2016-10-20
RichJ53
Vortex Drone Se Posted at 2016-10-20 19:19
Hey Vortex
Glad you are up and running again~
Happy flying
Rich
2016-10-20
DJI-Jamie
Vortex Drone Se Posted at 2016-10-21 10:19
Great to hear! Thanks for the update.
2016-10-21
