Go App flight records incorrect - can you edit?
1433 2 2016-10-16
SimonW
Flight distance : 1098635 ft
Hi All
Got a couple of issues with the Go App, in the flight records section:
1. Top Altitude shows incorrect on the front page, yet accurate within the actual records when you drag them up.
2. When I swipe left, I get the records for my P3A but on swiping left again I get a single flight record for an Inspire - I've never seen one in the flesh, let alone flown one!
Is it possible to amend/edit these records, or any tricks to get better accuracy? I've already removed/reinstalled the app etc.
Otherwise, I find the app pretty good.
Thanks
2016-10-16
ekcook
Flight distance : 553914 ft
I've posted and read questions in this and other forums/groups concerning the flight record data getting screwed up, so far no luck yet.  Mine went through a bunch of "failed to sync" errors after the last update, and when it finally did I lost a whole bunch of accumulated flight data.  Several hours of flight time, over 250K total distance, and several dozen flight times suddenly disappeared from both devices I use.
The fact I lost he data across multiple devices running (at the time) different versions of DJI Go, different make/model and android versions leads me to look at the DJI server side of the process.
Apparently we are not the only ones, the standard advice DJI-whoever gives is to re-install the DJI Go app/wait on the unspecified server issue to get resolved/make sure all firmware is updated/try Wifi instead of data/try data instead of WiFi..... wash rinse repeat.
2016-10-18
Geebax
No, you cannot edit the flight records, in any event they are encrypted in their native form.
2016-10-18
