Eye Spy
Flight distance : 531467 ft
Hello members,
I'm a newbie to P4 having just made 3 test flights for a total of 18 minutes. So far everthing seems to function perfectly. (I haven't used any advanced features - tap, POI, follow me etc.) I flew in an emply soccer field about 120M square. no wind, no spectators.
A couple of questions:
What is the most efficient flight mode, or in other words, what speed would give me my best miles-per-gallon? (distance/battery usage) I know the max velocities for each mode P,S,A. Also, if I flew at max altitude (500M) is that height significant enough to increase range?
So far, I've only test flown to a height of 30M and a distance of 54M, but I like to be (menatlly) prepared for a bad situation....
Second question. If I fly indoors (I haven't yet) can I use A-Mode but activate the Visual Positioning System. I seen to recal reading that P-Mode cant rely on the GPS system and may casue the P4 to wander...
Last question. In your opinion does one use the RTH feature ONLY as a last ditch attempt to recover the P4? (I havent tested that feature yet)
Thanks
