Cetaman
Flight distance : 2528264 ft
Aloha wor_nh,
There is an update for the DJI GO app to 3.0.0, the Remote Controller to 1.8.0 and the P3P Aircraft already has 1.8.80. If you research DJI firmware updates and upgrades the basic process is upgrade the DJI GO app first. Next only turn on the Samsung Tab A and the Remote Controller. Make sure you have a good WiFi and Internet connection. Do not turn on the Phantom. The DJI GO app will tell you to update the RC. Be sure to tap the download symbol at the end of the progress bar. Wait for the download to finish and then install the download. When you are done turn everything off.
You are concerned about the pixelation involved in this upgrade. If you turn everything off for ten minutes or over night, when you turn it back on again, the pixelation will be gone, at least the major pixelation I was experiencing was gone when I turned it back on. I did the full upgrade today, but I was using a nVidia Shield K1 device (Android), a P3P remote controller and a P4 aircraft. I had full window pixelation, usually more than 80% coverage in green screen. Last time I turned it on, it was perfect. So, there is a light at the end of the tunnel, you just got to trust the locomotive to get you there!
Finally, if you had to, you would download the aircraft firmware, but there is no update available for the P3P. But, if you did, you would extract the .bin file out of the zip download at the "Downloads" page of the DJI web site. In your Windows File Explorer program (or whatever Apple has), you would copy that extracted .bin file to the root directory of your micro SD card you use to record video with your P3P. The root directory is the first level labeled by the Drive letter. If you go to a lower directory, the .bin file will not work.
You would have the Phantom off when you inserted the micro SD card and then you turned the Phantom on. The small LED lights above the camera will blink red and green as the Phantom beeps a special code. When the beep changes to a different code and the LED camera light is solid green, the FW upgrade is done.
This description is a full system upgrade and that does not always happen. The P3P is not doing one this time but the P4 is doing a full system upgrade and the P4 uses the laptop or desktop computer based DJI Assistant 2 to do part of the job.
Hope this helps!
Aloha and Drone On! |
