Flight Log not sync in DJI Go 3.0.0
1571 26 2016-10-19
RemusE
Flight distance : 1145869 ft
Sweden
Since I updated to DJI Go 3.0.0 (Android) my Flight log does not synchronize anymore. It fails.
I saw that since then it created a new profile called "Phantom 4". My last 2 flights was made after the update and both contains the "new" name.
All my previous log was for "picmov" aircraft.
I did not renamed anything, I just updated my DJI Go.
2016-10-19
RemusE
Sweden
I got into the DJI catalog with a file manager and saw that the first Flight Log after update was 0 kb :/. I delete that file and DJI Go still failes to sync.
2016-10-19
DJI Natalia
Flight distance : 318 ft
Hi RemusE, would you please provide us your dji account username? we'll try to check it.
2016-10-19
RemusE
Sweden
DJI Natalia Posted at 2016-10-20 09:58
2016-10-20
DJI Natalia
Hi RemusE, have you tried to connect another network to sync?
If still fails, please export flight records manually and upload files to dropbox, then provide us the link, thanks.
You could connect your Android phone to a PC, and find \DJI\dji.pilot\FlightRecord\, then save that on your PC and upload to dropbox.
2016-10-20
RemusE
Sweden
DJI Natalia Posted at 2016-10-20 13:01
If still fails, please export flight ...
I've tried to both home network and work network. Same results.
zip file with the latest 4 logs
2016-10-20
RemusE
Sweden
A new flight yesterday, same results. The log is keeping fail to synchronize.
2016-10-20
DJI Natalia
RemusE Posted at 2016-10-21 12:46
I tried to download the files for several time, it keeps saying data error.
Would you mind trying with another mobile device for your next flight and check whether you can sync flight records?
2016-10-21
RemusE
Sweden
DJI Natalia Posted at 2016-10-21 10:14
Would you mind trying ...
https://dl.dropboxusercontent.com/u/3137586/dji.pilot.zip
What about this link?
2016-10-21
DJI Natalia
This one works, and i could sync it successfully manually on the iPad.
Please have a try with another mobile device when flying next time, or please delete the APP, re-install it.
Besides, when you try to sync it, what the percentage it will go? or just stay with 0 then failed after a while?
2016-10-21
RemusE
Sweden
DJI Natalia Posted at 2016-10-21 11:59
Please have a try with anoth ...
It goes to 97% then says failed.
Will re-install the app. Maybe the video glitch will disappear too ;).
2016-10-21
DJI Natalia
RemusE Posted at 2016-10-21 18:16
Will re-install the app. Maybe the video glitch will disappear to ...
Hope so, please keep us posted for the two issues, thanks.
2016-10-21
RemusE
Sweden
DJI Natalia Posted at 2016-10-21 12:24
I've re-installed the map, but no DJI folder was created. Will try to connect to aircraft later and see if I get then a DJI folder. It's a little strange that I cannot get the DJI foldr from the beginning.
2016-10-21
RemusE
Sweden
I flyied today with the new and and the FlightRecord did not sync either. It goes to 100% then says that it fails.
This is only one of the issues. The other issue is the video glitch in the other thread
2016-10-21
calls4u2
Flight distance : 211604 ft
Factory reset out manually clear everything dji from the tablet. I had exactly the same and opted for factory reset on the tablet. Phone I've not done yet so still same problem. Issue is the latest app, and maybe dji servers too.
2016-10-22
RemusE
Sweden
calls4u2 Posted at 2016-10-23 04:21
Factory reset out manually clear everything dji from the tablet. I had exactly the same and opted fo ...
I removed the new app, installed 2.9.1. The sync worked. So the problem is the new app (3.0.0) on my Android phone. It's raining today but I am pretty sure that I would not get any video glitch with the old app.
2016-10-22
RemusE
Sweden
I added a short movie with the synchronization for version 3.0.0.
Log Sync
2016-10-23
RemusE
Sweden
Any news about the log sync issue? Or should I wait for 3.0.1 for Android?
2016-10-25
Murilo Carmello
Flight distance : 1562549 ft
exactly the same problem is happening to me after I have installed version 3.0
2016-10-25
3exSXNknDvAu
Flight distance : 481939 ft
Murilo Carmello Posted at 2016-10-25 07:49
Same problem here with DJI Go 3.0.x -- reaches anywhere between 97% and 100% (inclusive) and reports failed.
Android 5.0.2 on HTC One M7.
2016-10-25
calls4u2
3.01 out for android now. This bug persists. As mentioned earlier, COMPLETE clean install and it seems to work... ie factory reset of tablet/phone
2016-10-25
calls4u2
So 3.01 shows my last flight as being in June. It also shows that I have an inspire as well as a p4, in fact it shows 4 p4s. Tried rolling back dji app but all flight logs since June are... Gone...
2016-10-25
Murilo Carmello
Brazil
For me, problem solved with DJI GO 3.0.1.
2016-10-25
ron.davis
Flight distance : 916818 ft
Murilo Carmello Posted at 2016-10-25 20:52
Did you update an existing install or uninstall prior version and install 3.01 fresh?
2016-10-25
RemusE
Sweden
I updated to 3.0.1, the sync it still says Failed but then it shows that everything is in cloud. The log is dispalying now in ft instead of metrics as before.
2016-10-26
Murilo Carmello
ron.davis Posted at 2016-10-25 21:08
I just updated
2016-10-26
Murilo Carmello
RemusE Posted at 2016-10-26 05:15
I updated to 3.0.1, the sync it still says Failed but then it shows that everything is in cloud. The ...
The same to me with the 3.0.0, but despite the error message, note that appears that is in the clouds, so I opened the APP in my tablet and it was updated
I noticed that I received the error message and did not rise to the clouds, so I tried again to climb into the clouds, , then one momento it appears is in the clouds, even the error message
Even with the error message, do not worry, just watch it will show the cloud icon right
2016-10-26
